Welcome @GreekMesh!
Note: Before you set your graphics tolerance to a finer level, read the last section of this post.
The issue you’re seeing appears to simply be a rendering issue. For example, I’ll show the render facets using the command:
graphics mode facet
The “factory default” graphics tolerance is 15 degrees:
As you can see, there are some large facets that neighbor some very high aspect-ratio triangles. This is efficient for rendering, but can lead to the visual discrepancies you’re seeing.
If we change the graphics tolerance to an angle of 1 degree we’ll notice that the variance in triangle size/shape is much smaller:
graphics tolerance angle 1
And if we set our graphics mode to back shaded:
graphics mode SmoothShade
you’ll notice that the visual discrepancies are gone:
README
So why don’t we have the factory default render tolerance finer than 15 degrees? From a previous post I made, once you set a graphics tolerance angle smaller than 15 degrees you’ll start to notice deteriorating performance:
So what I’ll often do in my scripts is initialize them with a render tolerance of 15 degrees, then when I want to work interactively, I’ll set the angle finer. So to modify your script, I would do:
reset
graphics tolerance angle 15 ## Maximize performance
######################## Create Vertices ############################
create vertex x 70.76 y 40.41 z 57.97
create vertex x 70.73 y 39.84 z 58.39
create vertex x 70.69 y 39.41 z 58.74
create vertex x 70.58 y 38.78 z 59.29
create vertex x 70.26 y 38.01 z 60.16
create vertex x 70.1 y 37.67 z 60.56
create vertex x 69.86 y 37.55 z 60.9
create vertex x 69.63 y 37.46 z 61.23
create vertex x 69.48 y 37.26 z 61.52
create vertex x 69.39 y 36.82 z 61.88
create vertex x 69.31 y 36.35 z 62.25
create vertex x 69.28 y 35.51 z 62.76
create vertex x 69.19 y 34.66 z 63.34
create vertex x 69.17 y 34.12 z 63.65
create vertex x 69.23 y 33.56 z 63.89
create vertex x 69.03 y 32.8 z 64.49
create vertex x 69.37 y 32.25 z 64.4
create vertex x 69.62 y 31.81 z 64.35
create vertex x 70.06 y 31.2 z 64.17
create vertex x 70.38 y 31.02 z 63.9
create vertex x 71 y 30.82 z 63.32
create vertex x 71.48 y 30.65 z 62.86
create vertex x 71.96 y 30.48 z 62.39
create vertex x 72.41 y 30.33 z 61.94
create vertex x 72.62 y 29.58 z 62.05
create vertex x 72.85 y 28.82 z 62.14
create vertex x 73.08 y 28.19 z 62.17
create vertex x 73.36 y 27.34 z 62.21
create vertex x 73.8 y 27.27 z 61.72
create vertex x 74.1 y 27.41 z 61.3
create vertex x 74.58 y 28.27 z 60.32
create vertex x 74.76 y 29.19 z 59.66
create vertex x 75.01 y 29.7 z 59.08
create vertex x 75.13 y 30.19 z 58.68
create vertex x 75.05 y 30.9 z 58.41
create vertex x 75.07 y 31.66 z 57.98
create vertex x 75.19 y 32.53 z 57.34
create vertex x 75.25 y 33.3 z 56.83
create vertex x 75.08 y 34.36 z 56.41
create vertex x 74.56 y 35.69 z 56.28
create vertex x 74.04 y 36.86 z 56.21
create vertex x 73.43 y 37.78 z 56.4
create vertex x 72.8 y 38.19 z 56.94
create vertex x 72.41 y 38.58 z 57.17
create vertex x 71.89 y 39 z 57.54
create vertex x 71.52 y 39.29 z 57.8
create vertex x 71.26 y 39.62 z 57.9
create vertex x 71.03 y 39.93 z 57.96
######################## Create Polyline-Create Sphere-Imprint Curve on Spherical Surface ############################
create curve polyline vertex all
create curve vertex 48 1
create sphere radius 100
imprint surface 1 with curve all
zoom surf 3
graphics tolerance angle 1 ## Maximize quality
