You’re very close… a few comments:
cubit.cmd('merge all')
cubit.cmd('imprint all')
99.9% of the time, you want to imprint all first, and then merge all second
#make set assignments
cubit.cmd('block 1 vol 1')
cubit.cmd('block 2 vol 3')
cubit.cmd('block 3 vol 2')
cubit.cmd('webcut volume in block 1 2 with plane xplane offset 2995')
cubit.cmd('webcut volume in block 1 2 with plane yplane offset 2995')
cubit.cmd('webcut volume in block 2 with plane zplane offset -1800')
The point of imprint and merge in this context is to connect/reconnect disconnected volumes to enable a contiguous mesh. Doing imprint/merge and then webcutting (partitioning) defeats the purpose.
So you’ll want to reorganize to this:
# Make set assignments
# Partition for meshability
# Ensure contiguous mesh
Looking at the geometry immediately before the imprint all command, I find it helpful to visualize vertices with vertex vis on. Essentially, your earlier webcut of the green and yellow volumes with the magenta surface:
Results in some modification to some of the bounding curves – visualized here as red vertices:
Those vertices are indicators that those curves are “split” – meaning that the topology of the volume has changed and may not be recognizable to Cubit as meshable with the polyhedron scheme. However, assuming that it’s not otherwise critical to the simulation that we exactly maintain the topology (e.g., you’re not applying a boundary condition only to one half of the now-split curve) we can tell Cubit to ignore those vertices in the topology of those volumes, treating the two split curves as a single composite curve:
cubit.cmd('composite create curve all angle 1')
Note that we want to do this before we imprint so that the topology won’t be accidentally “frozen” into merged entities:
I also reorganized your meshing a bit:
# Assign mesh schemes
cubit.cmd('volume all scheme auto')
cubit.cmd('vol in block 1 scheme tetprimitive')
cubit.cmd('vol 3 5 8 9 scheme polyhedron')
# Assign mesh sizes
cubit.cmd('vol in block 1 size '+str(elementsize1))
cubit.cmd('vol in block 2 size '+str(elementsize2))
cubit.cmd('vol in block 3 size '+str(elementsize3))
# Mesh volumes
cubit.cmd('mesh vol all with has_scheme "polyhedron"')
cubit.cmd('mesh vol all with has_scheme "tetprimitive"')
cubit.cmd('mesh vol all except with is_meshed')
You might find this documentation page useful to understand the with has_scheme "polyhedron" and except with is_meshed commands:
https://coreform.com/cubit_help/cubithelp.htm#t=environment_control%2Fentity_selection_and_filtering%2Fextended_entity_specification.htm
So the final combined script is:
elementsize1 = 80
elementsize2 = 80
elementsize3 = 80
cubit.cmd('reset')
cubit.cmd('sphere radius 1200.0')
cubit.cmd('volume 1 move x 2995 y 2995.0')
cubit.cmd('webcut vol 1 with zplane')
cubit.cmd('delete vol 1')
#volume 3
cubit.cmd('vol 2 copy')
cubit.cmd('brick x 7000 y 7000 z 5000')
cubit.cmd('volume 4 move x 3500 y 3500 z -2500') # origin 0, 0, 0 [0, -5000]
cubit.cmd('volume 4 move x -500 y -500') # [-500 6500]
cubit.cmd('subtract vol 3 from vol 4')
cubit.cmd('undo group begin')
cubit.cmd('compress')
cubit.cmd('import "topo_coarse.cub" ')
cubit.cmd('import "layer3_coarse.cub" ')
cubit.cmd('webcut vol 1 2 tool body 3')
cubit.cmd('delete vol 5 6')
cubit.cmd('delete body 3')
cubit.cmd('webcut vol 2 tool body 4')
cubit.cmd('delete body 4')
cubit.cmd('sideset 1 surface 2 4')
# avoids assigning empty blocks
cubit.cmd('set duplicate block elements on')
# Virtual geometry cleanup
cubit.cmd( 'volume all scheme auto' )
# Assign mesh sizes
# Mesh the volumes
# View the mesh
cubit.cmd( "draw block all" )
