Hello.
I’m trying to export a 640k element hex mesh as an exodus file. I keep getting the following error:
ERROR: Could not export the data to a file.
I’m using Trelis 17.1 Pro (linux version). I read some other threads that suggest that this might be a
- export setting issue
- memory issue
As far as #1 is concerned, I’ve tried every setting, including those suggested in some other threads (Error when exporting mesh as Exodus file).
If it is #2, i.e. my computer with 16 GB of RAM with 32 GB scratch space isn’t adequate, could you please suggest how to proceed? Is it possible to build Cubit/Trelis on an HPC machine, create the mesh and export it there?
Thanks.
