Weird python inconsistency
Coreform Cubit 2022.9 & 2022.11 - Fedora
Truely mind bending error, I have a python script which takes in a bunch of planes, does some maths - largely irrelevant. However, I’ve spent an ungodly amount of time tracking this down, but bizzarely, when running the same script inside of Coreform Cubit and in my system python I get different results!
When I run this script;
#!/usr/env/python3
import numpy as np
def plane_intersect(a, b):
    a_vec, b_vec = np.array(a[:3]), np.array(b[:3])
    aXb_vec = np.cross(a_vec, b_vec)
    A = np.array([a_vec, b_vec, aXb_vec])
    d = np.array([-a[3], -b[3], 0.]).reshape(3,1)
    # could add np.linalg.det(A) == 0 test to prevent linalg.solve throwing error
    print(f'A={A}')
    print(f'd={d}')
    p_inter = np.linalg.solve(A, d).T
    return p_inter[0]
plane1 = [0,0,-1,0.946948223999989]
plane2 = [0,1,0,-0.124051900705194]
x = plane_intersect(plane1,plane2)
print(x)
print(np.__version__)
On my system I get; - which is the correct result
A=[[ 0  0 -1]
 [ 0  1  0]
 [ 1  0  0]]
d=[[-0.94694822]
 [ 0.1240519 ]
 [ 0.        ]]
[0.         0.1240519  0.94694822]
1.22.0
Inside of Cubit I get
A=[[ 0.  0. -1.]
 [ 0.  1.  0.]
 [ 1. -0.  0.]]
d=[[-0.94694822]
 [ 0.1240519 ]
 [ 0.        ]]
[[-0.94694822  0.1240519   0.        ]]
array([-0.94694822,  0.1240519 ,  0.        ])
Note how the inputs are identical, but the output vector is reversed!
I am at a loss to explain this, any ideas?
Even simpler one;
import numpy as np
a = np.array([[1.,2.],[3.,4.]])
b = np.array([2.,1.])
print(np.linalg.solve(a,b))
In system python,
[-3.   2.5]
In Cubit
[-0.94694822  0.1240519 ]
I’m at a loss
I’m assuming that you meant something a little different for that last example from Cubit? Same values but different order?
Nope, flat out different values. I re-ran it today to make sure I wasn’t crazy.
System python:
[-3.   2.5]
Coreform Cubit:
[-5.73021895e-300  6.90234151e-310]
So I’m now thinking its due a system library being pointed to rather than the shipped Coreform version.
I should point out I switched out to scipy.linalg and it runs fine.
I can’t seem to replicate this on my end:
I’m getting consistent results with your simpler problem as well. With Coreform Cubit 2022.11 I get
This result is with
%>sys.version
'3.10.5 | packaged by conda-forge | (main, Sep  1 2022, 12:25:28) [MSC v.1928 64 bit (AMD64)]'
%>np.__version__
'1.22.3'
and using the system python I get the same results.
This result is with
>>> sys.version
'3.9.7 (default, Sep 16 2021, 16:59:28) [MSC v.1916 64 bit (AMD64)]'
>>> np.__version__
'1.24.1'
Same result with different versions of python and different versions of numpy both executed on Windows.
What version of python and numpy are you using?
