WARNING: Unable to retrieve RGB values
Dear all,
Whenever I create geometry or execute some commands I get the stream of messages:
WARNING: Unable to retrieve RGB values: Subscript (1171050880) out of range.
WARNING: Unable to retrieve RGB values: Subscript (14477501) out of range.
WARNING: Unable to retrieve RGB values: Subscript (1306271456) out of range.
which drastically slows down the processing for large models. Is there any fix for those warnings?
HNG
Did you change some setting related to color? You might try restoring settings related to colors to their default values.
Thanks a lot for the suggestion! Unfortunately that didn’t solve the problem but switching to anohter machince resolved the issue.
Best,
HNG
