We use the state of the art MeshGems library (recently acquired by Dassault Systems) to provide tetmesh capabilities. This error message is generated from inside this third party library.
I typically see this error message when the surface mesh is poor. The node ids given are identifiers internal to MeshGems and don’t have any value from a Cubit perspective.
Look for small surfaces or small edges and remove them or composite over them. If this is an STL file that you are remeshing, make sure that the original STL triangles don’t intersect or overlap. If the STL file is poor, I would recommend a third party application to cleanup the original facets. I have had success using blender for facet model cleanup.
Use the geometry power tool to find small surfaces and see if those could be removed or cleaned up in another way maybe by creating composite surfaces. Check the quality of the surface mesh before tetmeshing. If there are just a few bad triangles you might be able to select an edge and swap the edge via the context mesh option.
Some are from a .sat file? Are you mixing geometry engines?
