Very strange problem with sphere meshing
Dear all,
I have Trelis 16.3, 16.0 and Cubit 13.2. When I try to mesh a sphere with a simple journal commands:
create sphere radius 4
volume 1 size 0.8
volume 1 scheme Sphere
mesh volume 1
Trelis give very strange mesh. As I posted previously, nonplanar faces are also visible everywhere! But with the Cubit 13.2, I get correct mesh. Please see attached figures. What is so stange to me is that even if I change the mesh size, mesh in the trelis remains unchanged! Can anyone or anyone from the support team help on this please?
Best,
HNG
It looks like the default sphere scheme values changed sometime after Cubit 13.2, because this same behavior is also in Cubit 15.4 and Trelis 16.4. The defaults are now:
Volume 1 meshing scheme set to Sphere
graded_interval = 2 (Default)
az_interval = 8 (Default)
bias = 0.397887 (Default)
fraction = 0.500000 (Default)
max_smooth_iterations = 0 (Default)
You should change these values to the values below to get the similar sphere mesh you got in 13.2.
graded_interval = 6 (Default)
az_interval = 32 (Default)
bias = 0.75 (Default)
fraction = 0.250000 (Default)
The new journal commands would be:
volume 1 size 0.8
volume 1 scheme Sphere graded_interval 6 az_interval 32 bias 0.75 fraction .25
mesh volume 1
More information about the parameters can be found here:
csimsoft.com/help/trelishelp.htm … sphere.htm
Thank you so very much! I now got the finer mesh, but some elements have nonplanar faces. Please see attached figure. I plotted those coordinates in matlab, they are indeed NOT planar. This causes a serious problem when computing Jacobian in FEM/SEM. Do you have any suggestion?
Best,
HNG
