I am trying to make sure my geometry is good before I proceed with the meshing.
I have run “validate volume all” and received no errors.
But then I tried to run “Geomdebug Validate body all” and I got several messages saying the following:
[code]WARNING: Non-manifold topology at curve 54 on volume 2 may result in false errors being reported.
ERROR: Mesh.jou (22)
Incompatible CoFace senses found at curve 54 in volume 2.
Surface CoFace Sense CoEdge Sense
17 forward forward
11 forward forward[/code]
What does it mean “Incompatible CoFace senses” ? How do I fix this error ? Does this error messages means that I should not proceed with meshing until I fix all these errors ? Why did the “validate volume all” did not report any errors ?
A summary of the steps that I took so far were:
- Imported ACIS geometry
- imprint all
- merge all
- validate volume all
