Uspline in non-commercial license
Does the non-commercial license come with uspline feature/plugin? All my uspline related commands lead to segmentation error.
(Non-Commercial License) Cubit>help uspline
The following keywords are supported in CUBIT:
?                     curve                geomdebug            measure         project smooth    shaded               topology
adjust boundary       cylinder             geometry             merge           propagate         sheet                torus
align                 dag                  graft                mesh            pwd               side                 tquad
align mesh            debug                graphics             meshcut         pyramid           sidebc               transfer
arrangement           decompose            group                meshedit        pyramid mesh      sideset              transform
at                    default              hardcopy             meshmatch       qtri              simplify             transparent
auto                  defeature            healer               metadata        quality           size                 tri
auto_clean            delete               help                 mkdir           quit              skin                 tri2quad
barset                diagnostic           hex                  ml              read              sleep                tridelaunay point placement
bc                    die                  hexset               modify          rebar             smooth               trim
beep                  dir                  hiddenline           modify_iso      reclassify        smooth iterations    trimesher
block                 dis                  highlight            morph smooth    record            smooth method        tweak
blunt                 disassociate mesh    history              mouse           redraw            smooth tolerance     uncross
body                  discover_topology    hole                 move            reduce            snap                 undo
boundary_layer        disp                 htet                 new             refine            solver_element       unite
brick                 display              import               next            refresh           sphere               unmerge
bug                   draw                 imprint              nine            region            split                unpillow
capture               echo                 improve              node            regularize        stitch               up
case                  edge                 inflate              nodebc          remesh            stop                 validate
cd                    eight                info                 nodeset         remove            subtract             version
chop                  elembc               intersect            offset          renum             surface              vertex
classify              equivalence          interval             open            renumber          swap                 view
cleanup               exit                 invalidate owners    pan             reset             sweep                virtual
clear usermodified    exodus               join                 parser          restore           system               volume
closestpt             expect               journal              partition       resume            taper                walton_sculpt
coarsen               export               label                pause           reverse           target               warning
collapse              extract              laminate             paver           rotate            tet                  weavedata
collapse angle        face                 learn                pick            save              tetdice              webcut
color                 facet bbox           legacy               pillow          scale             tetmesh              weight
column                facet_modify         legacy sweeper       playback        scheme            tetmesher            where
comment               factor               line                 plot            scheme auto       tetset               whiskersheet
compare               find                 linebc               poinbc          sculpt            thex                 windows
composite             five                 list                 point           section           thicken              wireframe
compress              freesmooth           locate               predict         select            tile                 xgrid
control skew          from                 logging              preview mesh    sensor            timer                ygrid
copy                  frontdata            ls                   prism           separate          title                zoom
create                frustum              match intervals      project         set               tolerant mesh
(Non-Commercial License) Cubit>version
	Coreform Cubit Version 2025.12 Build 3d8d3af7
	VTK Version 9.2.2
	OpenGL NVIDIA Corporation NVIDIA GeForce RTX 3050 OEM/PCIe/SSE2 3.2.0 NVIDIA 535.230.02
	ACIS Version 33.0.0.0
	CAMAL Version 17.4.3
	MeshGems Version 2.15-5
	Mesquite Version 2.99
	Revised Mon Dec 1 17:05:34 2025 +0000
Journaled Command: version
Hi @hemiao,
as far as i remember the uspline functionality was removed with Cubit 2023.8.
You would need to use a older release with a valid commercial or academic license.
For what exactly do you need usplines?
Hi Norbert,
I was following an example in MOOSE. I also posted a question on their discussion forum. They are currently adopting to more recent version of Cubit.
Is there any workaround from Cubit side?
I got no workaround for this. You would need to use an older Cubit Version with a valid license.
Hi
Could you please advise how I can obtain an academic license for an older Cubit release (prior to 2023.8) that still includes the U-spline functionality?
I am currently working in an academic context and would like to use U-splines for research purposes.
Hi Ayah,
To obtain an academic license for Coreform Cubit, which will allow you access to our current version and all previous version, contact sales@coreform.com.
