Hey,
i started using Trelis in combination with python and i want do use the variable name of some vertices to create a surface (see code below). Does this work?
v1 = cubit.cmd(‘create vertex {} {} {}’.format(0, 0, 0))
v2 = cubit.cmd(‘create vertex {} {} {}’.format(0, 1, 0))
v3 = cubit.cmd(‘create vertex {} {} {}’.format(0, 0, 1))
surf1 = cubit.cmd(‘create surface vertex {} {} {} {} {}’.format(v1, v2, v3))
Best Regards
Andreas
karl
May 17, 2021, 1:08pm
2
No that will not work. The cubit.cmd() method does not return any useful information. You could use the extended interface that is more pythonic.
Try something like this.
v1 = cubit.create_vertex(0,0,0)
v2 = cubit.create_vertex(1,0,0)
v3 = cubit.create_vertex(1,1,0)
v4 = cubit.create_vertex(0,1,0)
cubit.cmd( "create surface vertex {} {} {} {}".format(v1.id(), v2.id(), v3.id(), v4.id() ) )
If you want to keep surf1 around you have to create curves using create_curve() or create_spline() and pass a list of curves to create_surf().
Hey Karl,
ok I understand.
Many thanks for your reply.
Best Regards
Andreas
