I have created a mesh where all the units for the input surfaces are in feet. During my meshing process I always used ${Units(‘ft-lbf-s’)} at the beginning of my journal files.
When I export the mesh in exodus format I obtain length dimensions in feet, which is consistent with what I expect.
I would like to know if it would be possible to convert the units of “length” in my mesh from feet to meters before exporting the mesh? See example below.
If this is not possible, then the only way to obtain the mesh in units of meters is to convert the original surface to meters and redo the meshing, correct?
Command to convert units to meters
Export the mesh
export mesh “./output/Mesh.exo” dimension 3 overwrite
