Dear all,
I’m currently automating an abaqus mesh optimization with meshes generated from Trelis. I’m able to generate a mesh in Trelis and Python with the same code, but when I try to run the same code in Abaqus, the following error pops up:
File “C:/Program Files/Trelis 16.5.4/bin/cubit.py”, line 28, in
_cubit = swig_import_helper()
File “C:/Program Files/Trelis 16.5.4/bin/cub.py”, line 24, in swig_import_helper
_mod = imp.load_module(’_cubit’, fp,pathname, description)
RuntimeERror: Import error: module not found.
Has anyone experienced the same issue or do someone know a possible solution for this?
Thank you very much in advance
Best regards,
Laurens
