I have a simple geometry that I’d like to mesh into hexahedra. However, without specifying a scheme, Cubit makes a tetrahedral mesh. Why would it do this? How can I reset the default sweep scheme ?
Here is the journal file:
create surface circle radius 200 xplane
sweep surface 1 perpendicular distance 5000
create surface circle radius 700 xplane
sweep surface 4 perpendicular distance 1200
move volume 2 x 1000 include_merged
webcut volume 2 with sheet extended from surface 2
delete volume 3
webcut volume 1 with sheet extended from surface 9
webcut volume 1 with sheet extended from surface 8
webcut volume all with general plane x offset 3200
webcut volume all with general plane x offset 4200
Best regards,
Rocco
