Surface normal vector at a given node
Hi Everyone,
I wish to obtain the surface normal vector at a given coordinate (preferably at a given node) using python script. I tried using the following syntax but gives error. Could someone please elaborate by giving a small example. I believe the ‘surface’ object is creating trouble.
Moreover, in the above syntax, how may decimal places do I need to include while passing the coordinates ?
Secondly, how to know if the normal is the outward normal or inward normal for a given curved surface ? I am particularly interested in the outward vector only.
Thirdly, is there a function that simply return the surface normal vector at a node id irrespective of the surface to which the node belongs ?
Thank you !
Best regards,
Aakash
Hi Aakash,
You have to have a Surface object to work on first. You can do that with the surface method. It takes the id of an existing surface. For example,
s = cubit.surface(25)
There is no node object. You can get the nodal coordinates with
coord = cubit.get_nodal_coordinates(95)
where 95 would be the node id.
Combining the two you can get the normal at the location on the surface s.
normal = s.normal_at(coord)
All floating point values in CubitInterface are double precision. The return value in the variable normal would look like
(-0.9665517094956546, 0.2393232310814618, 0.0922072878668329).
The input values of functions that take floating point numbers are always converted into double precision values. In the case of the normal_at method, if the input is [0,0,0] that will be converted to double precision zeros prior to the computation. The number of decimal places will affect the value of the normal slightly especially in a complex spline surface. You need to decide the level of accuracy needed.
The surface orientation is a function of the surface. If the surface is part of a volume and the surface is not merged, the orientation will always be outward. If the surface is merged (shared between two volumes) this becomes a little more difficult. Let me know if that is a problem.
You can visually display the normal of any surface with the draw surface normal command. For example,
draw surface 18 normal length 1
The length is optional but it sometimes helps to see the normal arrow if draw it at a longer length.
There is no single method to return the surface at a node id. The surface normal is a property of the surface and you must give a location on the surface.
I would recommend watching the video Coreform Cubit: Powered by Python - YouTube it may answer a number of you python related questions.
Dear Mr. Karl,
Thank you very much for your amazing description as always, Hopefully this technique would fulfil all my requirements.
With best regards,
Aakash
