Coreform Cubit Version: 2024.3
Platform: Windows 11
Issue
I have a STEP file that contains many line segments. When I import this file into Cubit 2024.3 (first image below), it seems to be missing approxiamtely half the lines in the file. Importing the exact same file into Cubit 2021.5 (second image below) it imports correctly. Is this a potental bug?
few-lines.stp (42.4 KB)
Hi @johnsonha,
yes this looks like a bug. I will report this to the devs.
Thank you @Norbert_Hofbauer.
I was also wondering if there was a way in Cubit to merge these line segments such that they are a single curve. I’ve tried using the Create Curve combine curve command with no success.
Hi @johnsonha,
create curve combine curve all only works for connected chains of ACIS curves. In your step file they get imported as spline curves.
Here is a short example.
create curve arc radius 1 center location 0 0 0 normal 0 1 0 start angle stop angle
split curve all fraction 0.5 from start
