I need your help to understand something. I am creating a circle, meshing it, and exporting it. I get the warning that “Dimension of block is greater than user specified output dimension.” What is the reason for the warning?
CUBIT> create surface circle radius 1.0 zplane
Journaled Command: create surface circle radius 1 zplane
CUBIT> mesh surf 1
Surface 1 (Surface 1) meshing scheme automatically set to pave.
Meshing Surface 1 (Surface 1)
Smoothing Surface Mesh
Generated 140 faces for Surface 1 (Surface 1).
Surface 1 (Surface 1) meshing completed using scheme: pave
Meshing time: 0.032000
Journaled Command: mesh surface 1
CUBIT> export mesh “test.g” dimension 2 overwrite
WARNING: Dimension of block is greater than user specified output dimension
Block 1 dimension = 3
User specificed output dimension = 2
I haven’t created any 3d entity??! Please advise!
