I just installed a fresh copy of Trelis 16.1.3 on MacOS sierra. I’m on a network license, and that seems to work.
I can run command-line, for example
Trelis-16.1 -nographics -nojournal -batch script.jou
works as expected.
But if I try to start the application with graphics, the program segfaults. The GUI window with the splash screen flashed briefly, and then the application dies.
If I do it in the terminal, I get the output appended to the end of this post.
Are there any logs, or any other way I could troubleshoot this problem?
Jonas
Trelis-16.1
usb support disabled
0x7f9bc23cdc90 ( QScreen(0x7f9bbef0d9d0, name=“Color LCD”) ): Attempt to set a screen on a child window.
0x7f9bc2485af0 ( QScreen(0x7f9bbef0d9d0, name=“Color LCD”) ): Attempt to set a screen on a child window.
0x7f9bc23d4630 ( QScreen(0x7f9bbef0d9d0, name=“Color LCD”) ): Attempt to set a screen on a child window.
0x7f9bc248a140 ( QScreen(0x7f9bbef0d9d0, name=“Color LCD”) ): Attempt to set a screen on a child window.
0x7f9bc248bf70 ( QScreen(0x7f9bbef0d9d0, name=“Color LCD”) ): Attempt to set a screen on a child window.
0x7f9bc248d9b0 ( QScreen(0x7f9bbef0d9d0, name=“Color LCD”) ): Attempt to set a screen on a child window.
0x7f9bc23d8740 ( QScreen(0x7f9bbef0d9d0, name=“Color LCD”) ): Attempt to set a screen on a child window.
0x7f9bc2490260 ( QScreen(0x7f9bbef0d9d0, name=“Color LCD”) ): Attempt to set a screen on a child window.
Segmentation fault: 11
