I am trying to use Sculpt to mesh a domain for an external flow problem.
The main idea would be to import the STL, create a sort of a bounding box containing the STL for the external domain, perform a boolean operation to cut the STL part from the bounding box and then to mesh the remaining with Sculpt.
However, I am not able to perform the cut operation, being the STL and the geometry two different object models.
Do you have any suggestion for how to handle such mesh problems?
Next go the Mesh tab. Click the Mesh Void checkbox and then you can select the Mesh Void Only option. I would suggest setting a block ID for the elements in the void.
