Hello all,
I have a geometry for which I applied circle and hole meshing schemes to mesh several of its surfaces. There is no problem to do that, however, when I reopen the cubit file I have got an error message saying (for example):
“Unable to restore CUBIT_HOLE meshing scheme on surface 5075”, and
“Unable to restore CUBIT_HOLE meshing scheme on surface 5136”.
I have got similar messages for several surfaces with hole or circle as their meshing schemes.
I wondered if this error is serious, and if so how I can solve it.
Just as a follow-up, after I contacted CUBIT forum, it seems that this problem is caused by an issue in setting the circle/hole schemes. Nevertheless, it does not hurt the subsequent process on the mesh data (e.g., exporting .cub file to other file format).
