Typically, I would would initiate a journal file with the “reset” command, which resets the current environment. However, I’ve found that this does not remove variables created from previously executed journal files (simple example at bottom). Is there a command that removes variables created from a journal file analogous to the reset command? This can cause undiscovered problems when working with multiple journal files within the same instance of Trelis.
Markus
Execute alpha:
{test_var=10}
Execute beta:
brick x {test_var} y {test_var} z {test_var}
Since the variable test_var is still in memory when executing beta, a brick is created.
