I was trying to rename the group using set_entity_name(“group”, 3, “watever2”) in python script instead of cubit command. But it seemed to work on other entity types than groups. I did see though the new names were added to the group name as an alias, if I “list group 3” as shown below. Is there a way in python script to change the group name instead of using cubit commands?
thanks.
Wei
CUBIT> list group 3
Group Entity ‘watever’, ‘watever2’ (Id = 3)
It owns/encloses 1 entity: 1 volume.
The general philosophy of CubitInterface is that it is read only. The only way to change state via the interface should be vis cubit.cmd() or cubit.silient_cmd(). Unfortunately, set_entity_name() creeped in for a use case in the GUI where the command line did not behave as needed.
The right way to set the group name would be as follows.
