I want to remove the tiny surfaces which are created when I import the following facet file:
How can I remove the two tiny surfaces 1 and 3? I want a solid surface of surface 2 for which I was going to mesh surf 2 using map and then create a net surface.
Because each of the two small surface share only one curve with the main surface, you can export the mesh of just the main surface and re-import the mesh as a single surface. Try this:
