For chords closer to the centre (e.g. on the red line), I want more nodes. For chords further away from the centre (e.g. on the yellow line), I want fewer nodes. Any strategy for this while keeping the mesh conformal?
Mesh: cubit01.cub (8.7 MB)
Have you already tried to first mesh the top surface with a coarse mesh and then do some refinement before you sweep from top to bottom?
open "/home/user/coreform/cubit01.cub"
reset vol all
split body 3 6 7 8
webcut volume 1 with plane from surface 55
webcut volume 18 with plane from surface 52
webcut volume 18 with plane from surface 61
delete vol all with x_coord<0
imprint vol all
surface 141 size 2
mesh surface 141
refine curve 187 numsplit 1 bias 1.0 depth 15
refine curve 187 numsplit 1 bias 1.0 depth 10
volume 9 11 13 16 redistribute nodes on
volume 9 11 13 16 scheme Sweep sweep transform least squares propagate bias
mesh vol 9 11 13 16
