From which data is your model imported?
Looking at the engine, it says facet. This means we got a faced-based geometry.
If you would check for overlaps with the power tools
Cubit will print a message with
ERROR: Currently, Cubit is unable to determine overlap for Facet-based geometry.
That doesn’t get us nowhere. so how are we sure that it’s really overlapping?
consider this short example
create brick x 1
create brick x 1
move vol 1 x 1
find overlap
find overlap will tell us that surface 4 and 12 are overlapping. looking at it with the powertools it will say, that there is no problem. doing
intersect vol all
will end up with
so it is actually not really overlapping, more like it’s already touching but not penetrating.
so how does it look if we really overlap?
create brick x 1
create brick x 1
move vol 1 x 0.9999
find overlap
find overlap will tell us surface 4 and 12 overlap. same as before. looking with the powertools already tells us there is a problem
that’s unfortunately not an option in your case.
intersect vol all
will in fact create us a new volume. because it’s really overlapping.
as you’ve got a pretty complicated model here. there are two options.
• getting an acis model imported in cubit, so we can use the power tools
• sort out the overlapping pairs from find overlap with for example intersect vol 13 2176
intersect vol 13 2176 will produce a null intersection. so it’s not a overlap pair to worry about. when that’s done we can look how to actually solve the real overlaps
