Using cubit.cmd to build primitives through the python interpreter on Windows causes the interpreter to silently close. Is this expected behavior? If so, should we be passing some other command or function to keep the interpreter going for next commands?
This same behavior exists when issuing the same commands through a python script in the terminal.
When run through the “Play Journal File” in the Cubit GUI, the python script executes as expected.
System:
Windows 10 V21H1, Build 19043.1288
Cubit 2021.5.0 build dbeb186(64-bit)
Python 3.8.6
ACIS 28.0.2.0
