Hi
I’m importing an exodus file, and Im using the python API (Cubit 2021.5) to do some querying.
I’m wondering if I’m doing something wrong, but there are number of mesh-relevant commands that dont behave as I expect. In this instance, an example would be
num_nodeset = cubit.get_nodeset_count()
num_sideset = cubit.get_nodeset_count()
Which both return 0, where as the same model in the Cubit GUI shows me 5 sidesets. However, get_block_count works fine.
Simillarly,
blocks = cubit.parse_cubit_list("block","all")
Tells me I have 3 blocks, with ids 1,2 and 200002, when I pass that to get_block_tets() I get nothing.
So I’m a little confused, is there some setup i have to do to populate some data structures to make Cubit aware, or am doing something wrong?
Andy
karl
July 12, 2021, 2:20pm
2
Is this a typo? The second command should be
num_sideset = cubit.get_sideset_count()
With a trivial model in Cubit 2021.5 I get the correct results
brick x 10
vol 1 copy move x 12
sideset 1 add surface 5 11
sideset 2 add surface 1 7
nodeset 1 add surface 12
nodeset 2 add surface 4
nodeset 3 add surface 3 9
cubit.get_nodeset_count() returns 3 and cubit.get_sideset_count() returns 2
Hi Karl
I think the first one was my bad, that one is fine.
However, cubit.get_block_tets(1) returns nothing
Andy
karl
July 13, 2021, 12:45pm
4
Hi Andy,
The way the get_block_* functions work may not be what you anticipated. The function returns the entities that were specifically added to the block.
If you do the following:
brick x 10
vol 1 scheme tetmesh
mesh vol 1
block 1 tet all
and then execute
you will get the list of tetrahedra in the block.
If instead of adding the tets, you do
block 1 vol 1
you will get no tets returned because the only entity added to the block was the volume.
Does that make sense?
– Karl
