I am looking for advice on how to merge a geometry successfully after imprint. Below is the output message that I get when I try to merge my geometry. When I use the find overlap command I can see that there are few surfaces between volumes that were not merged. Why does this happen?
Let me know if you have any advice on to solve this problem.
Thank you in advance,
Josimar
Cubit>imprint all
Group imprint finished.
WARNING: Unmerging Surface 36.
WARNING: Unmerging Surface 62.
Updated volume(s): 8, 9, 13, 35, 45, 47
IMPRINT completed.
Finished Command: imprint all
Cubit>merge all
...Merging all features in the model
...Merging all Surfaces in the model
Consolidated 50 pairs of surfaces
...Merging all Curves in the model
WARNING: Attempting to merge two entities with same parent.
Vertex 39 (Vertex 39) and Vertex 953 (Vertex 953)
Check for sliver geometry in the vicinity
Vertex 940 (Vertex 940) and Vertex 941 (Vertex 941)
Vertex 942 (Vertex 942) and Vertex 943 (Vertex 943)
Consolidated 14 pairs of curves
...Merging all Vertices in the model
Consolidated 0 pairs of vertices
All detected matches successfully merged
Finished Command: merge all
