I installed the latest version of Cubit on my windows 10 computer. After launching Cubit, only a few GUI buttons function. All other buttons are missing or disabled. How to fix it?
Lixin
Lixin
Please open up a cmd prompt and perform the following commands:
set CUBIT_VERBOSE=5
C:\Program Files\Coreform Cubit 2022.4\bin\coreform_cubit.exe > C:\Users\%USERNAME%\cubit_output.txt
This will generate a file called cubit_output.txt in your user folder. Please attach it here.
Let’s try that again and put the second command in quotes, like this:
set CUBIT_VERBOSE=5
"C:\Program Files\Coreform Cubit 2022.4\bin\coreform_cubit.exe" > C:\Users\%USERNAME%\cubit_output.txt
That’s what I did, the same output:
Does the folder C:\Program Files\Coreform Cubit 2022.4\bin exist? Also, you should do this in a cmd prompt, not powershell.
sorry, I did on powershell, Here is the output:
[2022-05-12 12:12:39.071] [app_logger] [info] Using gui
[2022-05-12 12:12:39.931] [app_logger] [trace] rlm_dir: C:/Program Files/Coreform Cubit 2022.4/bin/licenses;C:/Users/lge/AppData/Local/Coreform/licenses
[2022-05-12 12:12:39.931] [app_logger] [debug] C:/Program Files/Coreform Cubit 2022.4/bin/licenses;C:/Users/lge/AppData/Local/Coreform/licenses
[2022-05-12 12:12:39.984] [app_logger] [debug] RLM initialized
[2022-05-12 12:12:39.984] [app_logger] [error] Couldn’t initialize RLM! RLM ERROR code: -102 → Can’t read license data
RLM Diagnostics at 05/12/2022 12:12
RLM version: 14.1BL3
RLM platform: x64_w4
OS version: 6.2
ISV name: csimsoft
Hostname: PC97795
User: lge
Working directory: C:\WINDOWS\system32
Environment:
RLM_CONNECT_TIMEOUT=<not set>
RLM_LICENSE=<not set>
RLM_NO_UNLIMIT=<not set>
RLM_PATH_RANDOMIZE=<not set>
RLM_PROJECT=<not set>
RLM_QUEUE=<not set>
RLM_ROAM=<not set>
RLMSTAT=<not set>
HTTP_PROXY=<not set>
csimsoft_LICENSE=<not set>
RLM hostid list:
706617f7 uuid=4C4C4544-005A-4D10-8043-C4C04F333333 disksn=00000_00_000000_00_1000A7_15_952FCC_F2.6 disksn=FZ1LQL9E a4bb6d3f79c9 00059a3c7a00 ip=134.79.113.229 ip=192.168.29.160
License files:
C:\ProgramData\Reprise\csimsoft
rlm_init() parameters:
1: C:/Program Files/Coreform Cubit 2022.4/bin/licenses;C:/Users/lge/AppData/Local/Coreform/licenses
2: C:/Program Files/Coreform Cubit 2022.4/bin/coreform_cubit.exe
3:
<none>
In license file C:\ProgramData\Reprise\csimsoft
(no server)
<none>
Roaming Licenses:
<none>
[2022-05-12 12:12:39.984] [app_logger] [error] No logins were valid: -1
[2022-05-12 12:12:40.724] [app_logger] [info] Valid Cubit Learn login
[2022-05-12 12:12:40.724] [app_logger] [info] Logged in
[2022-05-12 12:12:40.725] [app_logger] [info] Python version 0 selected
[2022-05-12 12:12:40.725] [app_logger] [info] Looking for Python
[2022-05-12 12:12:40.727] [app_logger] [info] Python not already initialized, initializing
[2022-05-12 12:12:40.727] [app_logger] [info] Application directory is C:\Program Files\Coreform Cubit 2022.4\bin
[2022-05-12 12:12:40.728] [app_logger] [info] python_lib path: C:\Program Files\Coreform Cubit 2022.4\bin\python310.dll
[2022-05-12 12:12:40.728] [app_logger] [info] python_dir: C:\Program Files\Coreform Cubit 2022.4\bin
[2022-05-12 12:12:40.728] [app_logger] [info] Found embedded python
[2022-05-12 12:12:40.751] [app_logger] [info] Version 3 interpreter found
[2022-05-12 12:12:40.758] [app_logger] [info] Cubit python initialized
[2022-05-12 12:12:40.758] [app_logger] [info] Starting broker
[2022-05-12 12:12:40.758] [app_logger] [info] Passing control to MachineControl
[2022-05-12 12:12:40.765] [app_logger] [debug] Dealer::restore_settings: loading QSettings from : C:/Users/lge/AppData/Roaming/Coreform/Cubit.ini
[2022-05-12 12:12:40.765] [app_logger] [debug] Dealer::restore_settings: no Python addons
[2022-05-12 12:12:40.765] [app_logger] [debug] Supervisor::Impl::load_plugins: Loading plugins from QCoreApplication::applicationDirPath : C:/Program Files/Coreform Cubit 2022.4/bin
[2022-05-12 12:12:40.765] [app_logger] [info] Loading plugin from path C:/Program Files/Coreform Cubit 2022.4/bin
[2022-05-12 12:12:40.769] [app_logger] [info] Attempting to load: cfplugincomp.ccl
[2022-05-12 12:12:40.769] [app_logger] [debug] ClaroPlugin::load: loading: C:\Program Files\Coreform Cubit 2022.4\bin\cfplugincomp.ccl
[2022-05-12 12:12:40.843] [app_logger] [error] LoadLibraryW error: C:\Program Files\Coreform Cubit 2022.4\bin\cfplugincomp.ccl The specified procedure could not be found.
[2022-05-12 12:12:40.843] [app_logger] [error] Error loading component cfplugincomp.ccl: The specified procedure could not be found.
Error loading component:
cfplugincomp.ccl
[2022-05-12 12:12:40.843] [app_logger] [info] Attempting to load: cfplugingui.ccg
[2022-05-12 12:12:40.843] [app_logger] [debug] ClaroPlugin::load: loading: C:\Program Files\Coreform Cubit 2022.4\bin\cfplugingui.ccg
[2022-05-12 12:12:40.935] [app_logger] [error] LoadLibraryW error: C:\Program Files\Coreform Cubit 2022.4\bin\cfplugingui.ccg The specified procedure could not be found.
[2022-05-12 12:12:40.935] [app_logger] [error] Error loading component cfplugingui.ccg: The specified procedure could not be found.
cfplugingui.ccg
[2022-05-12 12:12:40.935] [app_logger] [info] Attempting to load: coreformcae.ccg
[2022-05-12 12:12:40.935] [app_logger] [debug] ClaroPlugin::load: loading: C:\Program Files\Coreform Cubit 2022.4\bin\coreformcae.ccg
[2022-05-12 12:12:41.029] [app_logger] [error] LoadLibraryW error: C:\Program Files\Coreform Cubit 2022.4\bin\coreformcae.ccg The specified procedure could not be found.
[2022-05-12 12:12:41.029] [app_logger] [error] Error loading component coreformcae.ccg: The specified procedure could not be found.
coreformcae.ccg
[2022-05-12 12:12:41.029] [app_logger] [info] Attempting to load: cubitcomp.ccl
[2022-05-12 12:12:41.029] [app_logger] [debug] ClaroPlugin::load: loading: C:\Program Files\Coreform Cubit 2022.4\bin\cubitcomp.ccl
[2022-05-12 12:12:41.083] [app_logger] [error] LoadLibraryW error: C:\Program Files\Coreform Cubit 2022.4\bin\cubitcomp.ccl The specified procedure could not be found.
[2022-05-12 12:12:41.083] [app_logger] [error] Error loading component cubitcomp.ccl: The specified procedure could not be found.
cubitcomp.ccl
[2022-05-12 12:12:41.083] [app_logger] [info] Attempting to load: cubitcompgui.ccg
[2022-05-12 12:12:41.083] [app_logger] [debug] ClaroPlugin::load: loading: C:\Program Files\Coreform Cubit 2022.4\bin\cubitcompgui.ccg
[2022-05-12 12:12:41.145] [app_logger] [error] LoadLibraryW error: C:\Program Files\Coreform Cubit 2022.4\bin\cubitcompgui.ccg The specified procedure could not be found.
[2022-05-12 12:12:41.145] [app_logger] [error] Error loading component cubitcompgui.ccg: The specified procedure could not be found.
Do you have any other Qt or Python installations present in your PATH environment variable?
I just installed python 3.10.4
Cubit ships python and Qt in its own installation directory. If you have another installation of Python in PATH or have other Python-related environment variables like PYTHONHOME set, it can interfere with Cubit and Cubit will not function properly.
I did not install Qt or Python before you asked.
OK, glad we’ve ruled that out. It’s probably easiest if we hop on a quick zoom call to debug this further. When is good for you? I’m available from 9-5:30 EST tomorrow.
1:00 PM EST works for me
Just DM’ed you a zoom link
Got it. Thank you very much! Talk to you tomorrow.
For others who may read this, the problem was a previous version of Cubit present in PATH.
Hi scot, I got the same issue here. What procedure should I conduct to fix it? Thanks.
Look at your PATH environment variable. Are there any other versions of Cubit or other scientific computing programs in that variable?
Thank you, scot. Didn’t see any Cubit related variables in PATH. However, several installed sci programs are shown below.
Tecplot is likely the issue, we’ve seen issues related to them in the past. We have some of the same dependencies, but use different versions of those dependencies. How Windows works is that it looks in each folder in PATH to load required libraries from, and it goes in order. So if it finds a library in Tecplot with the same name as the one that Cubit requires, it’ll attempt to load that library instead of the one in Cubit. On Windows it’s generally considered good practice to keep things out of PATH as much as possible to prevent libraries from conflicting like this.
