So the memory usage in serial for this problem is 28 Gb, which is fine, I’m trying what will be a (hyper?) detailed problem, so going into 100x bigger isn’t really an issue. However, even running this on 4 nodes (with npernode=1) I get issues
Guaranteed Quality Threshold = 0.200000
Laplacian Iter: 1
Laplacian Iter: 2
Smoothing 2180663 hexes on 4 processors
Jacobi Opt Iter: 1, Num bad: 220234, Num poor: 269523, Min SJ: -0.999999
WARNING: Unconstrained curve optimization was used for at least one node.
Some nodes may not lie on owning curves.
(Use curve_opt_thresh = -1 to turn off behavior)
Jacobi Opt Iter: 2, Num bad: 184721, Num poor: 284976, Min SJ: -0.999999
Jacobi Opt Iter: 3, Num bad: 164867, Num poor: 289469, Min SJ: -0.999999
Jacobi Opt Iter: 4, Num bad: 149903, Num poor: 296794, Min SJ: -0.999999
Jacobi Opt Iter: 5, Num bad: 139408, Num poor: 294261, Min SJ: -0.999998
[cpu-p-388:50138:0:50138] Caught signal 11 (Segmentation fault: tkill(2) or tgkill(2) at address 0x51c60000c3da)
[cpu-p-390:61674:0:61674] Caught signal 11 (Segmentation fault: tkill(2) or tgkill(2) at address 0x51c60000f0ea)
[cpu-p-389:189458:0:189458] Caught signal 11 (Segmentation fault: tkill(2) or tgkill(2) at address 0x51c60002e412)
[cpu-p-391:253961:0:253961] Caught signal 11 (Segmentation fault: tkill(2) or tgkill(2) at address 0x51c60003e009)
==== backtrace (tid: 253961) ====
0 0x000000000004f6b5 ucs_debug_print_backtrace() ???:0
1 0x0000000000743feb CubitString::number<int>() ???:0
2 0x000000000063f6f6 CubitString::number<int>() ???:0
3 0x000000000065707a CubitString::number<int>() ???:0
4 0x000000000065c886 CubitString::number<int>() ???:0
5 0x000000000061d809 CubitString::number<int>() ???:0
6 0x000000000061ec24 CubitString::number<int>() ???:0
7 0x000000000048ef7e std::vector<CubitString, std::allocator<CubitString> >::~vector() ???:0
8 0x000000000047ddcb std::_Rb_tree<int, std::pair<int const, double>, std::_Select1st<std::pair<int const, double> >, std::less<int>, std::allocator<std::pair<int const, double> > >::_M_erase() ???:0
9 0x0000000000477db3 ???() /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt:0
10 0x0000000000462061 ???() /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt:0
11 0x0000000000469c5d ???() /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt:0
12 0x0000000000472862 ???() /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt:0
13 0x000000000043d368 ???() /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt:0
14 0x0000000000022555 __libc_start_main() ???:0
15 0x0000000000443bd7 ???() /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt:0
[cpu-p-391:253961] *** Process received signal ***
[cpu-p-391:253961] Signal: Segmentation fault (11)
[cpu-p-391:253961] Signal code: (-6)
[cpu-p-391:253961] Failing at address: 0x51c60003e009
[cpu-p-391:253961] [ 0] /lib64/libpthread.so.0(+0xf630)[0x2b02a21c5630]
[cpu-p-391:253961] [ 1] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x743feb]
[cpu-p-391:253961] [ 2] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x63f6f6]
[cpu-p-391:253961] [ 3] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x65707a]
[cpu-p-391:253961] [ 4] ==== backtrace (tid: 50138) ====
[cpu-p-388:50138] *** Process received signal ***
[cpu-p-388:50138] Signal: Segmentation fault (11)
[cpu-p-388:50138] Signal code: (-6)
[cpu-p-388:50138] Failing at address: 0x51c60000c3da
==== backtrace (tid: 61674) ====
[cpu-p-390:61674] *** Process received signal ***
[cpu-p-390:61674] Signal: Segmentation fault (11)
[cpu-p-390:61674] Signal code: (-6)
[cpu-p-390:61674] Failing at address: 0x51c60000f0ea
==== backtrace (tid: 189458) ====
[cpu-p-389:189458] *** Process received signal ***
/home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x65c886]
[cpu-p-391:253961] [ 5] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x61d809]
[cpu-p-391:253961] [ 6] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x61ec24]
[cpu-p-391:253961] [ 7] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x48ef7e]
[cpu-p-391:253961] [ 8] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x47ddcb]
[cpu-p-391:253961] [ 9] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x477db3]
[cpu-p-391:253961] [10] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x462061]
[cpu-p-391:253961] [11] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x469c5d]
[cpu-p-391:253961] [12] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x472862]
[cpu-p-391:253961] [13] [cpu-p-390:61674] [ 0] /lib64/libpthread.so.0(+0xf630)[0x2b83e9933630]
[cpu-p-390:61674] [ 1] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x743feb]
[cpu-p-390:61674] [ 2] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x63f6f6]
[cpu-p-390:61674] [ 3] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x65707a]
[cpu-p-390:61674] [ 4] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x65c886]
[cpu-p-389:189458] Signal: Segmentation fault (11)
[cpu-p-389:189458] Signal code: (-6)
[cpu-p-389:189458] Failing at address: 0x51c60002e412
/home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x43d368]
[cpu-p-391:253961] [14] [cpu-p-388:50138] [ 0] /lib64/libpthread.so.0(+0xf630)[0x2ac2043b2630]
[cpu-p-388:50138] [ 1] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x743feb]
[cpu-p-388:50138] [ 2] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x63f6f6]
[cpu-p-388:50138] [ 3] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x65707a]
[cpu-p-388:50138] [ 4] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x65c886]
[cpu-p-388:50138] [ 5] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x61d809]
[cpu-p-388:50138] [ 6] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x61ec24]
[cpu-p-388:50138] [ 7] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x48ef7e]
[cpu-p-388:50138] [ 8] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x47ddcb]
[cpu-p-388:50138] [ 9] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x477db3]
[cpu-p-388:50138] [10] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x462061]
[cpu-p-388:50138] [11] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x469c5d]
[cpu-p-388:50138] [12] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x472862]
[cpu-p-388:50138] [13] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x43d368]
[cpu-p-388:50138] [14] [cpu-p-390:61674] [ 5] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x61d809]
[cpu-p-390:61674] [ 6] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x61ec24]
[cpu-p-390:61674] [ 7] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x48ef7e]
[cpu-p-390:61674] [ 8] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x47ddcb]
[cpu-p-390:61674] [ 9] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x477db3]
[cpu-p-390:61674] [10] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x462061]
[cpu-p-390:61674] [11] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x469c5d]
[cpu-p-390:61674] [12] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x472862]
[cpu-p-390:61674] [13] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x43d368]
[cpu-p-390:61674] [14] /lib64/libc.so.6(__libc_start_main+0xf5)[0x2b83eaf19555]
[cpu-p-390:61674] [cpu-p-389:189458] [ 0] /lib64/libc.so.6(__libc_start_main+0xf5)[0x2b02a37ab555]
[cpu-p-391:253961] [15] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x443bd7]
[cpu-p-391:253961] *** End of error message ***
[cpu-p-390:61674] *** End of error message ***
/lib64/libpthread.so.0(+0xf630)[0x2b4e108a7630]
[cpu-p-389:189458] [ 1] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x743feb]
[cpu-p-389:189458] [ 2] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x63f6f6]
[cpu-p-389:189458] [ 3] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x65707a]
[cpu-p-389:189458] [ 4] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x65c886]
[cpu-p-389:189458] [ 5] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x61d809]
[cpu-p-389:189458] /lib64/libc.so.6(__libc_start_main+0xf5)[0x2ac205998555]
[cpu-p-388:50138] [15] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x443bd7]
[cpu-p-388:50138] *** End of error message ***
[cpu-p-389:189458] [ 7] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x48ef7e]
[cpu-p-389:189458] [ 8] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x47ddcb]
[cpu-p-389:189458] [ 9] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x477db3]
[cpu-p-389:189458] [10] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x462061]
[cpu-p-389:189458] [11] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x469c5d]
[cpu-p-389:189458] [12] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x472862]
[cpu-p-389:189458] [13] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x43d368]
[cpu-p-389:189458] [14] /lib64/libc.so.6(__libc_start_main+0xf5)[0x2b4e11e8d555]
[cpu-p-389:189458] [15] /home/dc-davi4/Coreform-Cubit-2021.5/bin/psculpt[0x443bd7]
[cpu-p-389:189458] *** End of error message ***
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpiexec noticed that process rank 3 with PID 253961 on node cpu-p-391 exited on signal 11 (Segmentation fault).
3 total processes killed (some possibly by mpiexec during cleanup)
