Overlapping Surfaces when clearly they arn't
Hello, I am importing a solidworks file into cubit and performing an imprint/merge command. Then when searching for overlapping surfaces I get multiple but with further investigation you can see they arn’t overlapping. Does anyone know why?
Hi @thallam,
as you haven’t shared the geometry there are a few things you could check.
How is your imported geometry scaled? How big is the distance between the surface pairs?
Have you checked the find overlap settings?
Are the found surface pairs within the range and tolerances?
