OpenFOAM Export?
Coreform Cubit Version: 2024.8
Platform: Fedora Core 41 (upto date)
Issue
It seems that either I’m using the OpenFOAM export incorrectly or there is a bug. I created a mesh (3d tets) and used the CFD toolbar to add inlet, outlet and walls. I export to openfoam directly, and I can see in the constant/polyMesh directory a bunch of files are created with the right sets of patches and names. When I run an OpenFOAM problem it crashes on the first timestep. If instead, I export the mesh in Fluent format, then use OpenFOAMs fluentToFoam tool, it works flawlessly.
The files are clearly different, and there is clearly missing information, should I post an example jou file?
Yes, if you can provide a journal file that would be very helpful!
