Numbering After Webcutting
Is there a way to know how Coreform Cubit does some of the numbering of nodes after webcutting? I created a simple example.
brick x 2 y 1 z 1
move volume 1 x 1 y 0.5 z 0.5
block 1 volume 1
block 1 elem type hex27
block 1 name "two-element"
volume 1 size 1
mesh volume 1
nodeset 1 surface with x_coord 0
nodeset 2 surface with x_coord 2
nodeset 3 surface with y_coord 0
nodeset 4 surface with y_coord 1
nodeset 5 surface with z_coord 0
nodeset 6 surface with z_coord 1
nodeset 1 name "n_left"
nodeset 2 name "n_right"
nodeset 3 name "n_bottom"
nodeset 4 name "n_top"
nodeset 5 name "n_back"
nodeset 6 name "n_front"
export mesh "two-element.exo" overwrite
Then I created the same example except I webcut it.
brick x 2 y 1 z 1
block 1 volume 1
webcut volume 1 with plane xplane offset 1
volume all size 1
export mesh "two-element-split.exo" overwrite
When I use the exodus python module to look at the node connectivity for the two elements, I get the disparity.
For mesh without webcut
array([[ 1,  2,  3,  4,  5,  6,  7,  8,  9, 10, 11, 12, 13, 14, 15, 16,
        17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27],
       [ 5,  6,  7,  8, 28, 29, 30, 31, 17, 18, 19, 20, 32, 33, 34, 35,
        36, 37, 38, 39, 40, 23, 41, 42, 43, 44, 45]], dtype=int32)
For mesh with webcut
       [ 6, 28, 29,  7,  5, 30, 31,  8, 32, 33, 34, 18, 17, 35, 36, 19,
        37, 38, 39, 20, 40, 41, 42, 23, 43, 44, 45]], dtype=int32)
Reason I am hoping to define a different node numbering scheme compared to the exodus defined 27 nodes hexahedron defined here Exodus: Exodus Element Types
Thank you for any help.
To predict the node numbering after a webcut seems pretty impossible to me unless you control the whole meshing order. The normal mesh order is to first mesh the vertices, then the curves, then the surfaces and then the volume. And for the next volume this will be repeated.
It sounds like you want to map the connectivity for a element. For that you only need to know the node numbering for the isoparametric element that you want to map. The
cubit.get_expanded_connectivity(“hex”,1)
will always return the connectivity based on the exodus element type. When cubit exports the mesh in a different format the exodus element connectivity gets mapped to the chosen solver element type.
So for example if i want to map the connectivity from hex20 exodus to the c3d20 calculix
https://www.dhondt.de/ccx_2.22.pdf#subsubsection.6.2.4
I could do it like this with the python api.
brick x 2 y 1 z 1
block 1 volume 1
block 1 elem type hex20
volume all size 1
import numpy as np
def map_hex_element(hex_element):
    nodes = np.array(cubit.get_expanded_connectivity("hex",hex_element))
    # swap position 13-16 with 17-20
    tmp_nodes = np.array(cubit.get_expanded_connectivity("hex",hex_element))
    for i in range(12,16):
        nodes[i]=tmp_nodes[i+4]
    for i in range(16,20):
        nodes[i]=tmp_nodes[i-4]
    return nodes
nodes_cubit = cubit.get_expanded_connectivity("hex",1)
nodes_calculix = map_hex_element(1)
for i in range(len(nodes_cubit)):
 print(f"index {i+1} cubit {nodes_cubit[i]} <--> calculix {nodes_calculix[i]}")
Do you need a export format that is not supported by cubit?
I do have a different numbering that I am using for a solver I am testing out. What I am doing is exporting the exodus mesh, and using the exodus module to look at the connectivity. https://sandialabs.github.io/seacas-docs/sphinx/html/exodus.html#exodus.exodus.get_elem_connectivity
I am seeing a discrepancy also when I use the cubit.get_expanded_connectivity(“hex”,1") for the hex27 case compared to the element connectivity the exodus module produces.
I am unsure if this is an issue with the exodus module or how it’s exported.
The ids gets mapped from cubit into the exodus format. I didn’t find a way to access the mapping out of cubit but you can for example view the mapping when you export with the hdf5 option with hdfview.
But there should also be a method in the exodus module that can get you access to the mapping.
What I am after is getting some method after exporting the mesh to get the same connectivity information as cubit.get_connectivity. The node_id_map while helpful does not provide me with element connectivity.
Hi @ccarranza,
you can use the node_id_map in a function to map the node ids.
brick x 2 y 1 z 1
block 1 volume 1
volume all size 1
export mesh "/home/user/test.e" overwrite
import exodus
import numpy
# open file
exo = exodus.exodus('/home/user/test.e')
# get element connectivity from file
block_id=1
elem_conn, num_blk_elems, num_elem_nodes = exo.get_elem_connectivity(block_id)
elements = numpy.empty([num_blk_elems, num_elem_nodes])
for i in range(num_blk_elems):
 for ii in range(num_elem_nodes):
  elements[i,ii] = elem_conn[i*num_elem_nodes + ii]
node_id_map = exo.get_node_id_map()
    nodes = numpy.empty([1, num_elem_nodes])
    for i in range(num_elem_nodes):
     nodes[0,i] = node_id_map[int(elements[hex_element-1,i]-1)]
    return nodes
nodes_exodus = elements[0]
nodes_exodus_mapped = map_hex_element(1)
 print(f"index {i+1} cubit {nodes_cubit[i]} <--> exodus {int(nodes_exodus[i])} <--> exodus_mapped {int(nodes_exodus_mapped[0,i])}")
@Norbert_Hofbauer Thank you for the help. That provides a lot of clarity. It seems such a change would else be required for any nodesets. How would I accomplish that?
@Norbert_Hofbauer Actually, I was able to figure it out using the same strategy of using the node map. Thanks again! I guess the only question I would have is how to display the nodes in the node set using the python api?
Another general question I had. The package I am testing out uses a wavefront solver. When I do not perform any webcutting, the solver works great. This tends to be an issue when I perform multiple webcuts.
I am not quite sure what you mean by that.
Do you mean to just draw the single nodes in cubit? Or drawing a label in cubit with the exodus ids?
About the solver. I would take a look at how the solver handles the mesh. Especially how the element import works. Are the any requirements that the mesh needs to fullfill?
Just how you can obtain the element connectivity as a list/array, I was wondering if there is a command to get the nodes in a nodeset.
For the solver, I think I figured out the issue. I need to renumber the node coordinates. One thing I wanted to ask. Maybe this is more appropriate for the exodus folks, but does the orientation of the numbering matter. I am not seeing one for the exdous equivalent. I am working to compare this 27 node hex element.
Here’s the benchmark example I am working on. I am looking to analyze the lid driven cavity with a uniform mesh and non-uniform mesh. The issue is that with the non-uniform which requires webcuts, the element number follow a pattern whereas the uniform all the elements follow a column wise structure. Here is the commands for both meshes.
Uniform
# {length = 1}
# {height = 1}
# {time_step = 0.05}
# {num_elem_length = 6}
# {num_elem_height = 7}
brick x {length} y {height} z {time_step}
move volume 1 x {length/2} y {height/2} z {time_step/2}
block 1 volume 1
block 1 name "lid-uniform"
curve with x_coord 0 and y_coord 0 interval 1
curve with x_coord 0 and y_coord 0 scheme equal
mesh curve with x_coord 0 and y_coord 0
curve with x_coord 0 and z_coord 0 interval {num_elem_height}
curve with x_coord 0 and z_coord 0 scheme equal
mesh curve with x_coord 0 and z_coord 0
curve with y_coord 0 and z_coord 0 interval {num_elem_length}
curve with y_coord 0 and z_coord 0 scheme equal
mesh curve with y_coord 0 and z_coord 0
mesh volume 1
nodeset 2 surface with x_coord {length}
nodeset 4 surface with y_coord {height}
nodeset 6 surface with z_coord {time_step}
nodeset 7 curve with y_coord 0 and x_coord 0
nodeset 8 node with y_coord {height} and z_coord {time_step} and x_coord > 0 and x_coord < {length}
nodeset 9 curve with y_coord {height} and x_coord 0
nodeset 9 curve with y_coord {height} and x_coord {length}
nodeset 1 name "left"
nodeset 2 name "right"
nodeset 3 name "bottom"
nodeset 4 name "top"
nodeset 5 name "back"
nodeset 6 name "front"
nodeset 7 name "pressure"
nodeset 8 name "lid"
nodeset 9 name "edges"
Non-uniform
# {length = 1}
# {height = 1}
webcut volume all with plane xplane offset 0.05
webcut volume all with plane xplane offset 0.25
webcut volume all with plane xplane offset 0.5
webcut volume all with plane xplane offset 0.75
webcut volume all with plane xplane offset 0.95
webcut volume all with plane yplane offset 0.3
webcut volume all with plane yplane offset 0.55
webcut volume all with plane yplane offset 0.7
webcut volume all with plane yplane offset 0.82
webcut volume all with plane yplane offset 0.91
webcut volume all with plane yplane offset 0.99
merge volume all
block 1 volume all
block 1 name "lid-2d-ivp-distorted"
volume all size 1
For a nodeset with id 1 you can use
cubit.get_nodeset_nodes_inclusive(1)
to get all nodes in the nodeset.
The same can be achieved with
cubit.parse_cubit_list("node",f"all in nodeset 1")
The orientation usually matters. Just like in my calculix example above. if i don’t reorder my hex20 connectivity i get in trouble with using the mesh in calculix.
this should be the numbering for the exodus hex27
Can your solver handle nonuniform meshes?
It can handle non-uniform meshes, but I think it struggles to handle non-sequential element assembly. In the two meshes that I provided, the uniform mesh numbers all the elements sequentially while the non-uniform does not. I am hoping to see if I can fix that within cubit.
