Coreform Cubit Version: 2023.11
Platform: macOS 13.6.1
Hi all,
I’ve been running into issues when trying to run Python scripts in Cubit when commands are split over multiple lines. For example, if using some code formatter such as Black, long commands get split over multiple lines to make the code PEP-8 compliant.
Something like the following works in Cubit:
cubit.cmd("select face 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25")
but this doesn’t:
cubit.cmd(
Here’s a full minimal working example:
import cubit
cubit.cmd("reset")
cubit.cmd("create surface rectangle width 1 height 1 zplane")
cubit.cmd("surface 1 scheme map")
cubit.cmd("surface 1 size 0.025")
cubit.cmd("mesh surface 1")
# Some arbitrary command that is intentionally very long so that it gets split
# across several lines
cubit.cmd(
The above example raises the following error:
%>cubit.cmd(
File "<string>", line 12
cubit.cmd(
SyntaxError: '(' was never closed
%> "select face 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25"
File "<string>", line 13
IndentationError: unexpected indent
File "<string>", line 14
SyntaxError: unmatched ')'
Do you have any suggestions for how to get around this, other than disabling the code formatter?
Cheers,
Pat
