Model contain overlapping surfaces
I received the following warning when I do
top4 add Volume 28 Volume 32 Volume 24 Volume 20
volume 28 32 24 20  size auto factor 8
However when I run find overlap surface all, there’s no overlapping surface pairs. How shall I address it?
radome_3layer.cub5 (405.8 KB)
Besides I did imprint and merge before meshing operations.
i can mesh your geometry with
reset vol all
Volume 4 8 16 12 scheme polyhedron
mesh volume 4, 8, 12, 16
What do the power tools show you when you run a check?
Well I can mesh it if I mesh the volumes 1 by 1. But if I choose several volumes together, the error occurs.
I
reset vol all solved the problem. Thank you :slight_smile:
