Meshing volumes with uneven hollow space within
Hi all,
I have a doubt regarding meshing uneven volumes.
here’s a picture of my initial meshed volume.
Later I webcut this volume along the z-axis into two bodies like in the following figure.
Now I wanted to know if it’s possible to mesh the whole volume first as in fig 1 and then webcut keeping the meshing scheme?
If not can anyone suggest a better way to mesh these volumes?
Welcome to the forum. You can not create an all quadrilateral mapped mesh around the arbitrary cut out. What you can do is create a rectangular region around the cutout and use that as a transition to an arbitrary quadrilateral mesh. I used an ellipse instead of you arbitrary shape, but the idea is the same.
For example,
create curve location -5 0 0 location 5 0 0
curve 1 copy scale .75
curve 2 move y 5
create surface skin curve 1 2
create surface ellipse major radius 1 minor radius .5 zplane
body 2 move x 2 y 3
create brick bounding box Surface 2  extended percentage 50
imprint body all
del body 2 3
surface all size .2
surface 4 scheme submap # this will ensure the regular grid in most of the surface
mesh surface all
Does this work for you?
Hi Karl,
Thanks for your response.
Your example was helpful in sorting the issue.
As my surfaces are more complex and uneven I have subdivided the surfaces into more blocks and meshed them separately using submap and pave schemes based on the irregularity of surfaces.
Athira
