Coreform Cubit Version: 2021.11 Platform: Windowd 10 Pro
Issue
New to meshing I’m trying to tet mesh this liver model so to generate a fine 40k tets volume, seems every time I’m trying some approach there is a problem I’m not able to overcome, so wanted to ask for some hint.
I have generated also this stl version of the shape filled with tet using Houdini Tet Embed node, seems is impossible to open it in Cubit but is opened in Gmsh telling there is no tet inside.
The issue with this model is that it does not form a closed set of triangles. Cubit is not the best tool out there so solve this problem, but in this case, I can get it to work. Remember tetrahedra are normally created on a closed volume. In your case, I will create a closed set of triangles, and tetmesh those.
My comments are in the journal file below.
import asset "~/Downloads/liver3-HD.obj" tolerance .001 make geometry on
create volume surface all noheal
# There are a couple of sliver surfaces that will create bad elements.
# Get rid of them.
composite create surface all
# I just wanted to see the surface mesh first.
surface 7 scheme trimesh
mesh surf 7
vol 4 scheme tetmesh
mesh volume 4
list totals
any way to enable the kind of visualization you have shown
57k it’s too much for my test and for my free license (so far testing on realtime sim system on CPU before switching to GPU, so 40k will be already too much), there is any way to impose or drive a lower number of generated tet, around the 40k I have written before
By default we don’t draw volumetric elements for rendering performance. However, you can use the draw command to force elements to be drawn. For example:
sphere r 1
vol 1 scheme tetmesh
mesh vol 1
graphics clip on
draw tet all
You can sign-up for a 30-day trial license, which has no element export limit. You can do this by logging into your Coreform account and then clicking on the link in your account portal:
You can modify the mesh size to attempt to create fewer elements. You can do this by modifying the surface and volume meshing parameters within the tetmesh scheme (larger angles, larger gradations, larger min size, etc):
