Meshing of sphere
Hi, I am new user of Cubit 13.1 version. I had a question about meshing using Hexahedral element. I modeled a partial sphere and cut it with cone and I am trying to mesh it with hexahedral element but it shows me volume not map, submap,seepable. If I cut the sphere on between into two halves still it cannot mesh. What should I make changes in design to make it sweepable.
create sphere radius 7.399 ypositive
create frustum height 4.87 radius 5.2 top 0 (cone created)
rotate Volume 2 angle 90 about X include_merged (rotated cone @X axis)
move Volume 2 x 0 y 2.87 z 0 include_merged (moved cone on yaxis)
webcut volume 1 with plane surface 4 (webcut sphere with cone circle)
delete volume 3 (deleted sphere bottom part)
delete volume 2 (deleted cone)
Partial spheres can be hex meshed by decomposing it into sweepable volumes using a cylinder. Try adding the following to your journal file:
#use a cylinder to core the partial sphere
create cylinder height 20 radius 1
rotate volume 4 angle 90 about X include_merged
webcut volume 1 with sheet extended from surface 9
delete volume 4
#cut the remaining partial cylinder into two sweepable volumes
webcut volume 1 with general plane yz
#imprint and merge volumes to ensure a contiguous mesh
Hi, Thanks for the earlier reply. Now I ma experiencing another problem after I added a cylinder to sphere and carried out the meshing but it can’t mesh volume1 (half spherical part after webcut). I have attached new code
delete volume 3
delete volume 2
delete volume 4
create Cylinder height 3.0 radius 5.15
rotate Volume 7 angle 90 about X include_merged
align Volume 7 surface 29 with surface 15
Would like to know why it’s happening. It is able to mesh volume 6 i.e. other half spherical with sweep meshing scheme but couldn’t mesh with sweep scheme.
When I run your journal file the cylinder is overlapping the two partial spheres. Is this what you intended?
[attachment=0]sphere.jpg[/attachment]
