Dear all,
I am trying to mesh many small cube structures attached to a big cube.
I did “imprint volume 1 to 105 with volume 106”
And then “merge all, compress all”
However, when `I want to mesh the volume 106, there’s the error as follows:
ERROR: Logical connection error for surface -1: no side traversal.
ERROR: SweepTool::problem meshing source surface 641
ERROR: Volume 106 meshing unsuccessful using scheme: sweep
ERROR: 1 volume did not mesh : Volume 106
Although some entities failed to mesh, Cubit will log the command in the journal file anyway, for future use.
Finished Command: mesh volume 106
Does anyone knows how to solve the issue?
Thank you very much!
Hi @sul_geo,
can you share the geometry that you want to mesh?
history.jou (33.1 KB)
Dear @Norbert_Hofbauer ,
In the attachment is the file of geometry I would like to mesh.
When I have less cube (such as 8), I could successfully mesh the geometry. But I failed to do it again with more cubes as this case.
Thank you.
Hi @sul_geo,
when the submap scheme fails you could try to use the pave scheme for the surface where the small volumes are merged.
Surface 106 scheme pave
mesh surface 106
I saw that your small volumes are all of the same size. Instead of creating a long journal you could also use the python mode to script the geometry creation and meshing.
# create base bricks
x_1 = 500
y_1 = 500
z_1 = 12
x_2 = 20
y_2 = 20
z_2 = 30
cubit.cmd(f"create brick x {x_1} y {y_1} z {z_1}")
cubit.cmd(f"create brick x {x_2} y {y_2} z {z_2}")
# create coordinates for copying
coordinates = []
start = [-125,-125,(z_1+z_2)/2]
delta_x = 25
delta_y = 25
n = 10
m = 10
for i in range(n):
for ii in range(m):
position = []
position.append(start[0]+i*delta_x)
position.append(start[1]+ii*delta_y)
position.append(start[2])
coordinates.append(position)
for coord in coordinates:
cubit.cmd(f"volume 2 copy move x {coord[0]} y {coord[1]} z {coord[2]}")
print("finished")
delete vol 2
imprint vol all
vol all size 4
cubit.cmd(f"surface all in volume 1 with z_coord = {z_1/2} scheme pave")
cubit.cmd(f"mesh surface all in volume 1 with z_coord = {z_1/2}")
Thank you so much for your help! Your suggestions are very helpful.
