Meshing cylinder with hemisphere top
I am trying to mesh a cylinder topped with a hemisphere. I have used a cicular mesh on the cylinder face and swept through to get a nice uniform mesh for the cylindrical volume. Now I am trying to mesh the hemisphere on the top, but I have not managed to do so.
I wonder if there is a built-in way to webcut it to achieve the desired mesh? or maybe a scheme to achieve the mesh I want?
I am attaching some images of the geometry I want to mesh, also the same geometry with the type of mesh I want that I created in ANSA using a built-in “o-grid” function.
Thanks!
/Anton
Hi @anton,
you can mesh it by decomposing the half sphere with 2 webcuts and assigning the polyhedron scheme afterwards.
Here is a short example
create sphere radius 1 zpositive
create Cylinder height 5 radius 1
move volume 2 z -2.5
webcut volume 1 with plane xplane offset 0
webcut volume 1 3  with plane yplane offset 0
imprint vol all
vol all size auto factor 4
volume 4 3 5 1 scheme polyhedron
mesh vol 4 3 5 1
grafik
Hi @Norbert_Hofbauer!
Thanks a lot this was exactly what I wanted!
