Meshing a volume that capsulated two hollow spheres beneath an undulating surface
Hi Team,
I have a surface with changing topography and there are two spheres at depth. It shows an error when I want to mesh the volumes! Could you please help me? I have attached the command line, the figure of my model, and the error. Thank you so much!
issue.jou (4.5 KB)
Hello @kianadmvnd,
when you are working with spheres keep in mind that you will probably need the polyhedron scheme. Which in this case fits perfect.
after the imprint and merge you just need to set the scheme for the sphere parts and its adjacent volumes to the polyhedron scheme.
vol all scheme polyhedron
vol all size 20
here is the complete journal file
create vertex location	-500	-500	154.663858
create vertex location	-400	-500	140.2466479
create vertex location	-300	-500	125.9735147
create vertex location	-200	-500	120.0525243
create vertex location	-100	-500	125.8781543
create vertex location	0	-500	140
create vertex location	100	-500	154.1218457
create vertex location	200	-500	159.9474757
create vertex location	300	-500	154.0264853
create vertex location	400	-500	139.7533521
create vertex location	500	-500	125.336142
create vertex location	-500	500	154.663858
create vertex location	-400	500	140.2466479
create vertex location	-300	500	125.9735147
create vertex location	-200	500	120.0525243
create vertex location	-100	500	125.8781543
create vertex location	0	500	140
create vertex location	100	500	154.1218457
create vertex location	200	500	159.9474757
create vertex location	300	500	154.0264853
create vertex location	400	500	139.7533521
create vertex location	500	500	125.336142
create curve spline location vertex 1 2 3 4 5 6 7 8 9 10 11 delete
create curve spline location vertex 12 13 14 15 16 17 18 19 20 21 22 delete
create curve vertex 1 12
create curve vertex 11 22
create surface curve all
brick x 1000 y 1000 z 500
move Volume 2  z -50 include_merged preview
surface 3 copy
delete volume 2
create volume loft surface 1 8
delete body 1 3
compress
create sphere radius 60
move Volume 2 x -120 z 40 include_merged
move Volume 3 x 120 z 72 include_merged preview
subtract volume 2 3 from volume 1 keep_tool
compress all
webcut volume all with plane xplane offset 120 preview
webcut volume all with plane xplane offset -120 preview
webcut volume all with plane yplane offset 0 preview
webcut volume all with plane zplane offset 50 preview
webcut volume all with plane zplane offset 40 preview
webcut volume all with plane zplane offset 60 preview
vol all size 20
Thank you for your assistance.
Another question: Is it possible to get the coordinates of a point on the surface which is not defined as a vertex?
Yes it is possible.
You can query that with the help of the python interface.
surf = cubit.surface(1)
on_off = surf.point_containment ([0,0,0])
print(on_off)
on_off = surf.point_containment ([10,0,0])
print(on_off)
