I am trying to mesh a very thin membrane and either get negative Jacobians (for thicker bodies) or the volume does not get meshed at all (this case). It is worth noting that the membrane has two circles on its top (loading regions), and those circles have quite different size, too.
The code below generates the basic geometry (1/4 of the domain because of symmetry). A few lines are added on the edges of the membrane to decompose the geometry.
brick x 0.5 y 0.5 z 0.002
move Volume 1 location 0.25 0.25 0.001 include_merged
create vertex 0 0.0007 0.002 color
create vertex 0.0007 0 0.002 color
create surface circle center vertex 4 10 9
imprint body all
delete body 2
delete vertex 9
create vertex 0 0.0007 0 color
create vertex 0.0007 0 0 color
create surface vertex 7 16 11 4
create surface vertex 15 7 4 12
imprint body all
delete body 4
delete body 3
create vertex 0 0.4 0.002 color
create vertex 0.4 0 0.002 color
create surface circle center vertex 4 26 25
imprint body all
delete body 5
delete vertex 25
create vertex 0 0.4 0 color
create vertex 0.4 0 0 color
create surface vertex 7 34 27 4
create surface vertex 7 33 28 4
imprint body all
delete body 6
delete body 7
I need to find a way to mesh this domain with quadrangles in both efficient and robust way since the code is going to be parametrized.
Some help would be much appreciated.
