I’m wondering if there’s any possibility to have mesh line colors on a per body instance? We often will compare 2d meshes by overlaying them, but it is difficult to do this when we cannot assign unique colors to each mesh.
Hi @pcristini,
yes it is possible. You just need to draw the edges with a color.
move surface 1 x 0.01 y 0.02
mesh surface all
draw edge all in surface 1 color blue
draw edge all in surface 2 color red add
Thank you @Norbert_Hofbauer !
Can you explain why this does not do the same thing?
color surface 1 mesh blue
color surface 2 mesh red
According to the docs
Including the Mesh keyword will change the color of the mesh belonging to the specified entity, without changing the color of the entity geometry itself.
The color used to draw mesh edges is the line color.
You can change that with color lines <color> but unfortunately you can’t specify any entity to get a specific line color. The best way to get different colors is with the draw command.
