I am trying to create a simple case
- I only want a layer of hexahedron with the given xyz to mesh this brick, I think if I can set the z of the element equal to the brick’s z
- I need to be able to give nodeset to the element of +x and -x at the y=0 surface, and number of elements for +x, and -x must be equal. For example, elements 123 and 456.
Here is my code now, I don’t know if webcut works, because I only need virtually group them, but physically they need to be connected, also need help in meshing etc
graphics axis type origin on
create brick width 10 depth 21 height 1
move volume 1 location 0 10.5 0.5
webcut volume all with plane xplane
#this is too uncertain
#surface 3 size 3
#surface 1 size 0.05
#This makes sure the cells are connected right?
imprint vol all
mesh volume 1
mesh volume 2
here is my result,
@Norbert_Hofbauer Thank you so much
Hi @miraboreasu,
as long as you don’t need to assign different materials you probably won’t need a webcut here.
When i stick to your sketch and want to control the number of elements here, i think it is the best to use the curves in the axis directions. After meshing you can create the nodesets with the use of the extended selection.
# x
curve 4 interval 6
curve 4 scheme equal
# y
curve 3 interval 10
curve 3 scheme equal
# z
curve 9 interval 1
curve 9 scheme equal
mesh vol 1
nodeset 1 add node all with x_coord <= 0 and y_coord = 0
nodeset 2 add node all with x_coord >= 0 and y_coord = 0
And yes, the imprint and merge commands are used to connect the entities proberly so that there will be no coincident nodes when everything is meshed.
A follow-up question, while z interval = 1, if I want the grids at both sides for x=0 (yoz) doing the refinement, bigger and bigger along with -x and +x, what should do, and also avoid the poor quality shape face
I am using this, but nothing changes
curve 4 scheme Bias
Thank you @Norbert_Hofbauer
You can make use of the dualbias scheme for this.
# x
curve 2 4 6 8 scheme dualbias fine size 1 coarse size 0.2
# y
curve 3 interval 10
# z
curve 9 interval 1
mesh vol 1
