merging of vertex and curves only for a certain volume
Dear all,
For merging two entities we use
merge vertex 1 2
merge curve 1 2
However, I have 2 contacting surfaces between two different volume. These volumes have multiple vertices and curves which are merge-able. When I do merge all, it also merges the contact surface. I could switch merge off for those two surface but I am interested to know if there is a method just to merge all the curves and vertex in a single volume like
merge vertex all in volume 1
merge curve all in volume 1
is there a command for that?
regards
You are real close. Here is an example
brick x 1
vol 1 copy move x 1
merge curve in volume all
You can also use
merge vertex in volume all
