List of hex of thousands of cells in a mesh
I am new in cubit, and I am trying to figure out how to extract the information of thousands of hex mesh cells. Specifically, I have a cylinder with 250,000 hex mesh cells, and I want to extract information about the cells, especially the centroids. I am currently using list hex ID through the GUI, but this is not efficient and very time-consuming, as it can’t print more than 60 IDs at the same time. Is there a way to extract this information faster and more efficiently and store it in a .txt file?
Thank you!
Hi @tsiaraf,
just use the python api for things like this.
Here is an example.
First we create some geometry and mesh it.
create cylinder r 1 height 10
vol 1 size auto factor 6
mesh vol 1
As the python api doesn’t have a function to get the centroid directly for a element, we will define us one.
def get_centroid(el_type,id):
  node_ids = cubit.get_connectivity(el_type,id)
  centroid = [0,0,0]
  for id in node_ids:
   coord = cubit.get_nodal_coordinates(id)
   centroid[0] += coord[0]
   centroid[1] += coord[1]
   centroid[2] += coord[2]
  centroid[0] = round(centroid[0]/len(node_ids),6)
  centroid[1] = round(centroid[1]/len(node_ids),6)
  centroid[2] = round(centroid[2]/len(node_ids),6)
  return centroid
Then we just need to query the hex ids for our volume
hex_ids = cubit.parse_cubit_list("hex","all")
When we have the ids we just make a loop and write the info into a file.
file = open("example.txt", "w")
for id in hex_ids:
 centroid = get_centroid("hex",id)
 file.write(f"hex id: {id} centroid x: {centroid[0]} y: {centroid[1]} z: {centroid[2]} \n")
file.close()
In your current working directory you should now find the example.txt with your requested data in it.
And here is the full input again, you just need to copy/paste and run it.
mesh vol 1
  centroid = [0,0,0]
  for id in node_ids:
  return centroid
for id in hex_ids:
file.close()
Great, thank you this is extremely helpful, I appreciate the detail in your response!
