Is there an option or a procedure to run a journal file done in GAMBIT? Additionally, is there a repository of journal templates with the syntax examples?
Thanks in advance.
Best regards,
Antonio
Thanks in advance.
Best regards,
Antonio
Although GAMBIT was branched from CUBIT, it was done many years ago. There may be older commands and syntax that may not work anymore in Trelis. Are you able to share your GAMBIT journal file?
Dear moderator,
thank you for your quick answer. Please, find attached the journal file done in GAMBIT 2.4.6. Additionally, I would like to know if there is a repository with journal templates ( syntax examples).
Sincerely,
Antonio
01_Ohba_bm.jou (40 KB)
Thank you. We don’t have a repository of journal files. I’ll suggest that we create a journal file sharing forum. I could create something like you are trying to do in GAMBIT as an example.
Dear moderator,
I appreciate your support and advice. This new journal file (TRELIS), with the commands that I have done in GAMBIT, will be very useful for me. Also, because I can use it as a template and as an example of syntax. I think that the new forum is a great idea, as well.
Thanks in advance,
Antonio
