imprint Tolerance surface seems to have a bug
this command seems to have a bug.
'imprint Tolerant surface %d curve ’
When I generate daughter surfaces based on this command the surfaces are skipped in some cases. I imprint 100 surfaces based on curve sets. Just two of the surfaces seem to be causing error. Is there any catch in using this command?
[code]# Imprinting of surface and making of new surfaces!
totalSurface = cubit.get_surface_count()
print " total surface = d " totalSurface
for surfaceID_s in range(1,totalSurface+1):
print “Surface ID %d” %surfaceID_s
COG_Surface =
COG_Surface=cubit.get_center_point(“surface”, surfaceID_s)
xCoord=COG_Surface[0]
yCoord=COG_Surface[1]
zCoord=COG_Surface[2]
print ("Creating center point for the surface ")
cubit.cmd('surface %d Copy Scale X 0.95 Y 0.95 Z 1 about %10f %10f 10f' (surfaceID_s, COG_Surface[0], COG_Surface[1], COG_Surface[2] ))
imprintSurfaceID= cubit.get_last_id(“surface”)
curve_list = cubit.get_relatives(“surface”, imprintSurfaceID, “curve”)
totalCurvesInSurface=len(curve_list)
b= 'imprint Tolerant surface d curve ' (surfaceID_s), ’ ‘.join(map(str, curve_list))
print b
print b[0]
print b[1]
cubit.cmd(’ %s s keep' (b[0], b[1]))[/code]
When using the tolerant imprint command, the entities you want to imprint must be closer than the ‘merge tolerance’ apart or the imprint will not succeed. Is it possible that this is the case? The merge tolerance can be modified by the following command:
merge tolerance 0.0001
It would be helpful if you could share the two cases that are failing.
