Import stp to cubit issue
I exported a design from AutoCAD as a .stp (STEP) file that contains 17 solid volumes. However, when I import it into Coreform Cubit, only 15 volumes appear. I also see two black regions in the model that I can’t select or interact with — it seems they didn’t import as valid volumes.
Here’s what I’ve tried so far:
  • Imported using import step "filename.stp" heal
  • Checked geometry count with list volume and list body
  • Attempted to heal geometry all and stitch surfaces all tolerance 1e-6
Still, those two missing parts remain black and non-selectable.
Has anyone encountered this is
sue before? Could it be caused by open surfaces or non-manifold geometry from AutoCAD? And is there a recommended workflow or setting to ensure all solids import correctly as volumes in Cubit?
Thank you in advance!
Hi @fakhar,
could you please share the step file. I would like to take a closer look.
4LFA_3D_Solid_with_name_of_materal.step (683.4 KB)
Hi @fakhar,
which Cubit Version are you using?
I got no issues importing all 17 volumes in Cubit 2025.8.
also , i use 2025.8 trial for 30 days
how i can make this this design like this , but still i have issue black and sole volume not importing
can i give you anydesk to check my problem , and help me , i want your help
Hi @fakhar,
for non-commercial users only the forum is available for support.
Which OS are you using to run Cubit?
Ubuntu 24.04.2 LTS, this is my os on vmware workstation
works fine if i run it on my Ubuntu 24.04
have you already tried to run cubit not in a vm?
NO , i’m not tried that
