CubitVersion: Cubit 2021.5
Platform: Mac OS 11.5.1
Issue
Importing Cubit Python on a Mac raised an error, just wondering if this has been imported correctly or there is a potential bug
We should be using Python 3.8 on all the systems. I don’t have a Mac easily available. Would you start up Cubit, go to the Python tab and enter
import sys
sys.version
to verify the version.
You could also look in the About dialog, but I’d rather get the answer from the source.
We build against the Mac OS native python install. This has caused fewer problems on Mac in the past. There is likely a difference in the Mac OS version on our build machine vs the Mac OS version that you are running. I don’t know what version our build machine is running.
We use a tool called swig to wrap the C++ interface for python and the swig tool is not python minor version independent (yet). You must run the same version of python as installed with Cubit to import Cubit.
We typically suggest running the python installed in Cubit to avoid any issues versions.
Understood
It looks like I can change my system python to 3.9 to match the internal Cubit Python and then import
conda create --name py39 python=3.9
Thanks for your speedy response
It is kind of funny timing as I was previously looking for python3.9 cubit Python 3.9 support in Cubit
