Howto create higher order elements?
I am new to Trelis and I was able to create tet meshes successfully. But I can’t find an option to create higher order elements, e.g. second order tets. How can I do that with the help of the GUI or the command line.
Thank you,
Thomas
Element type are assigned to blocks. You would create a block of the volume and then assign a type to the block. An example of the commands would be
bri x 10
vol 1 scheme tetmesh
mesh vol 1
block 1 vol 1
block 1 element type tetra15
Or you can use the GUI
Thank you for the detailed answer. It worked well.
